I want to know whether meta-agl layer is supported for Toradex BSP 5.0 with Apalis IMX6. If it is not then can you suggest us which platform to choose for AGL(Automotive Grade Linux).
Does meta-agl layer is supported in Toradex BSP 5.0 with Apalis IMX6. Will there be any build issue?
Hi Nitish,
As discussed in the below post Toradex does not maintain meta-agl layer.
Apart from this, from NXP they have some documentation available which you might like to try.
https://source.codeaurora.org/external/imx/meta-nxp-agl/
Ritesh Kumar
You are welcome.
