I understand your confusion about the suspend/resume documentation. You’re correct that the wording could be clearer. Let me clarify what the documentation means and the different approaches available.
Current Documentation Context
The documentation states that suspend/resume tasks “can be performed without root permissions inside a container” by using bind mounts for required files(1). However, this statement can be misleading because while the container itself doesn’t need to run in privileged mode, the operations still require elevated permissions.
Available Approaches
1. Bind Mount Approach (sysrq-trigger)
The documentation shows using /proc/sysrq-trigger which requires root access but can work in a non-privileged container:
docker run -it --rm -v /proc/sysrq-trigger:/procw/sysrq-trigger torizon/debian:4
echo "b" > /procw/sysrq-trigger
(1)
2. D-Bus Approach
The D-Bus method requires system-level permissions:
docker run -it --rm -v /var/run/dbus:/var/run/dbus torizon/debian:4
apt update && apt-get install -y dbus
dbus-send --system --print-reply --dest=org.freedesktop.login1 /org/freedesktop/login1 "org.freedesktop.login1.Manager.Reboot" boolean:true
(1)
Key Clarifications
The documentation mentions that “reboot via D-Bus is a more proper way to do it, since it will gently ask all daemons and containers to stop before reboot, while sysrq will not do that”(1). However, both approaches require elevated permissions - the difference is:
- Non-privileged container: The container doesn’t run with
--privileged flag
- Root permissions: The user inside the container still needs root access for system operations
Security Perspective
The documentation acknowledges the security implications: “From a security perspective, bind mounting /proc/sysrq-trigger, which allows performing some low-level commands, or /var/run/dbus, which provides access to system services, may potentially pose a vulnerability”(1).
Recommendation
Your implementation approach is correct - running containers as root user (or with sudo permissions) while avoiding the --privileged flag provides the necessary permissions for system operations while maintaining better security boundaries than fully privileged containers.
The documentation could indeed benefit from clearer language distinguishing between “privileged containers” (using --privileged flag) and “containers running as root user” to avoid the confusion you encountered.
