yesterday I did a fresh install of VSCode and Torizon IDE 3.6.0 with Torizon WSL 2 on Windows 11.
After connecting to device I checked /etc/docker/daemon.json on device. As meantioned in an older post, the IP under “unsecure-registries” was wrong.
I removed and added the device again and set to default, but the IP stays wrong. I corrected the entry by myself.
Is Toradex aware of this issue?
Here is my old post:
I’m sorry, but I don’t have specific documentation about this known issue with the Torizon IDE Extension not updating the insecure-registries IP address in /etc/docker/daemon.json when the network changes.
However, based on the documentation, when connecting to a device, the Torizon IDE Extension sets up Engineering Mode, which includes enabling your development PC’s IP as an insecure container registry(1). This configuration is added to /etc/docker/daemon.json on the device(1).
Since you’re experiencing this issue consistently after a fresh VSCode and Torizon IDE 3.6.0 installation, and the problem persists even after removing and re-adding the device, I recommend:
Check your network configuration: Ensure your development PC and target device are on the same network(1)
Verify the IP detection: Check what IP address your development PC is using on the network interface connected to the device
Manual workaround: As you’ve already done, manually correct the entry in /etc/docker/daemon.json on the device
Report the issue: Since this appears to be a recurring problem with the IDE Extension, consider reporting it through the Toradex Community with detailed information about your network setup (WSL2, Windows 11, network adapter configuration)
The community discussions you referenced suggest this may be related to how the IDE Extension detects the development PC’s IP address, particularly in WSL2 environments where network configuration can be more complex(2)(3).
The device and PC are in the same local network.
Device 192.168.179.12/24
PC 192.168.179.13/24
Output on IDE:
[07-09 08:00:47.625] Checking host ip sanity …
[07-09 08:00:48.884] Host ip is OK
[07-09 08:00:48.889] Device 192.168.179.12 set as Docker Host
IP in “unsecure-entries” on the device is set to: 192.168.179.3
There is not network device on this IP.
WSL vEthernet adapter is 172.22.176.1.
A VPN connections runs on an adapter with IP 192.168.113.3/24
Thank you for providing those details. This clarifies the issue — the Torizon IDE Extension is incorrectly detecting your host IP as 192.168.179.3 instead of your actual PC IP 192.168.179.13.
Based on the documentation, there is a known workaround for this exact scenario. The Torizon IDE Extension provides a setting to manually override the host IP detection(1).
Solution
You can set the torizon.overwriteHostIp setting in VS Code global settings to specify the correct IP address:
Open VS Code Settings (File → Preferences → Settings)
Search for torizon.overwriteHostIp
Set it to your correct PC IP: 192.168.179.13
According to the troubleshooting documentation: “This can happen when the host is using some VPN or other network configurations that may change the IP address of the host, or have multiple interfaces”(1). Your setup with a VPN connection on 192.168.113.3/24 and WSL vEthernet adapter on 172.22.176.1 is exactly the type of multi-interface configuration that can cause this issue.
The documentation specifically states: “To workaround this issue, you can set the torizon.overwriteHostIp setting in the VS Code global settings to the correct IP address from the main interface that the host is using”(1).
After setting this configuration, try reconnecting to your device. The extension should now use 192.168.179.13 when configuring the insecure-registries entry in /etc/docker/daemon.json on your device.
I set the VSCode setting torizon.overwriteHostIp to 192.168.179.13 and restart VSCode.
But reconnection (clear default, remove device, connect device, set default) does not put the host ip into the “insecure-registries” setting on device.
Could you try deleting the /etc/docker/daemon.json on the device before reconnecting. Maybe it’s the case that the old file isn’t being overridden.
Also do you see anywhere else in the extension that the incorrect IP address is being used? Or is it just in daemon.json where the iP address is incorrect?
The file was deleted. Reconnecting does not create the file. It’s gone.
That’s very strange, the file should be created on adding the device to the extension. Let me run this by our extensions team if there is a possible bug somewhere.
We’ve been unable to reproduce this issue on our end. In every case the /etc/docker/daemon.json file gets recreated when a device is added. So it’s strange that it does not get recreated on your setup.
Could you try to reproduce again on your side, but this time share the output of the internal logs during the process. To view the internal logs see the documentation here: Troubleshooting | Toradex Developer Center
In the meantime host-ip switched from 192.168.179.13 to 192.168.179.11. I changed this in the torizon settings (Overwrite host-ip).
console.ts:139 [Extension Host] [07-16 06:37:15.065] Device 820-26-0000.xxx.local removed as Docker Host
console.ts:139 [Extension Host] [07-16 06:37:16.834] Disconnecting from 820-26-0000.xxx.local ...
console.ts:139 [Extension Host] [07-16 06:37:16.846] Device 820-26-0000.xxx.local removed from local storage
console.ts:139 [Extension Host] [07-16 06:37:46.426] Trying to connect to 192.168.179.12
console.ts:139 [Extension Host] first login success, checking if we should change the default password...
console.ts:139 [Extension Host] Last login: Thu Jul 16 05:35:19 2026 from 192.168.179.11
** WARNING **
THIS DEVICE IS IN ENGINEERING MODE
Check for more info:
https://developer.toradex.com/torizon-engineering-mode
console.ts:139 [Extension Host] torizon@820-26-0000:~$
console.ts:139 [Extension Host] logged in!
console.ts:139 [Extension Host] exit
console.ts:139 [Extension Host] logout
console.ts:139 [Extension Host] ret from easy pairing ...
console.ts:139 [Extension Host] ret from easy pairing :: 1
console.ts:139 [Extension Host] ret from easy pairing2 ...
console.ts:139 [Extension Host] ret from easy pairing2 :: 1
console.ts:139 [Extension Host] ret from phobos setup 0 ...
console.ts:139 [Extension Host] ret from phobos setup 1 ...
console.ts:139 [Extension Host] ret from MOTD...
console.ts:139 [Extension Host] ret from END SETUP...
console.ts:139 [Extension Host] [07-16 06:37:56.254] Connected to 820-26-0000.xxx.local
console.ts:139 [Extension Host] [07-16 06:38:36.150] Checking host ip sanity ...
console.ts:139 [Extension Host] Last login: Thu Jul 16 05:37:53 2026 from 192.168.179.11
** WARNING **
console.ts:139 [Extension Host] [07-16 06:38:40.067] Host ip has been updated OK
console.ts:139 [Extension Host] [07-16 06:38:40.071] Device 192.168.179.12 set as Docker Host
Actually wait, did you actually try the debug process to see if it succeeds or fails?
I just recalled that the latest versions of our VSCode extension have a completely different method of deploying containers to the device. This new method doesn’t really rely on the settings in /etc/docker/daemon.json anymore.
So debug should work fine for you, can you please confirm.
Good to know.
In the past I had trouble with Docker because of a wrong IP in the “unsecure-registries” setting and since then, I check the setting in /etc/docker/daemon.json and overwrite it with a valid IP.
Yes. I deleted the file and debug/Docker has no problem.
