The docker command works well for our single container application. We’re trying to run multi container app with docker-compose. However, docker-compose repose with the error below. How can this be fixed?
Tnx, Dov
apalis-imx6-10492181:~$ docker-compose
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 583, in _build_master
ws.require(__requires__)
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 900, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 791, in resolve
raise VersionConflict(dist, req).with_context(dependent_req)
pkg_resources.ContextualVersionConflict: (requests 2.21.0 (/usr/lib/python3.7/site-packages), Requirement.parse('requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1'), {'docker-compose'})
During handling of the above exception, another exception occurred:
File "/usr/bin/docker-compose", line 6, in <module>
from pkg_resources import load_entry_point
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3191, in <module>
@_call_aside
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3175, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3204, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 585, in _build_master
return cls._build_from_requirements(__requires__)
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 598, in _build_from_requirements
dists = ws.resolve(reqs, Environment())
File "/usr/lib/python3.7/site-packages/pkg_resources/__init__.py", line 786, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'requests!=2.11.0,!=2.12.2,!=2.18.0,<2.21,>=2.6.1' distribution was not found and is required by docker-compose
