Docker 29.x on Ubuntu causes "no matching manifest for linux/arm64/v8" and Compose v5.0.0 crash
Thank you for filing the GitHub issue for the containerd snapshotter incompatibility. This is an important step for tracking and resolving the Docker 29.x compatibility issues with the Torizon IDE Extension.
Issue Documentation and Community Support
Your bug report will help the Toradex development team prioritize this compatibility issue and potentially implement a proper fix in future releases of the VS Code extension templates. The containerd snapshotter problem affects the multi-architecture image handling that’s essential for the Torizon development workflow(1).
Related Community Issues
Similar Docker compatibility issues have been reported in the community. For example, there have been cases where TorizonCore Builder encounters Docker-related problems(2), and architecture detection issues in VS Code environments(3). Your detailed analysis and workaround documentation will be valuable for other developers encountering similar challenges.
Development Environment Considerations
While your workaround (disabling containerd-snapshotter and using Docker Compose v2.x) resolves the immediate issues, tracking this through the official GitHub repository ensures that future versions of the Torizon IDE Extension can properly support newer Docker versions without requiring manual configuration changes.
The Torizon platform is designed to simplify embedded development workflows(1), and maintaining compatibility with the latest Docker toolchain versions is important for the developer experience.
Next Steps
The GitHub issue will allow the development team to:
  • Investigate the root cause of the containerd snapshotter incompatibility
  • Develop a proper fix or alternative approach
  • Update the extension to handle Docker 29.x configurations automatically
  • Document any necessary configuration changes for users
Your contribution to identifying and documenting this issue helps improve the Torizon development ecosystem for the entire community.
