on our product, we only use USBH lines to connect with a USB Hub chip to provide USB Host interface, based on this application, do Do USBH_OC and USB_ID Pins can be used as GPIO on Colibri iMX6 under WinCE 7?
for HW side, i think there is no big issue, but on WinCE driver side, not sure if only disable USB OTG is enough as below article or more registry modified needed?
USBH_OC is used by the USB host driver, USB_ID is used by on-the-go. So you’ll have to disable both USB drivers at the moment. We plan to allow disabling of OC detection on host and you may configure the on-the-go controller as host or client only, making ID pin available as GPIO.
At the moment configuring the OC pin as GPIO generates some issues with USB devices.
