Our network operations team made some changes in our artifactory instance related to file sizes and such. I don’t understand why it worked for me and not you but hopefully the new settings will make it more reliable. Can you try the wget command again and let me know?
I know this post is very old but I think that my issue is related and I’m suspecting that the problem could be on your side.
I’m trying to build a project from scratch using this setup: $ repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.6.0 -m tdxref/default.xml
but the do_fetch operation of linux-toradex recipe fails when it tries to uncompress the downloaded file.
I tried to download it manually using the command used by bitbaket and it is downloaded correctly (apparently):
But then, I received the same error notified by bitbaket log:
tar -xzf git2_git.toradex.com.linux-toradex.git.tar.gz
gzip: stdin: invalid compressed data--crc error
tar: Child returned status 1
tar: Error is not recoverable: exiting now
Note:
As you can see, wget use a second retry to download the file. I don’t think this could be a problem.
I can fix the issue commenting the line (as you suggested):
INHERIT += "toradex-mirrors"
Question: do you know if there is an issue on your server similar to the commented time ago?
