I am using the Apalis Evaluation Board with Apalis i.MX6Q SOM board and the “Toradex Resistive Touch Display 7" Parallel”. The software version that I use is “Apalis-iMX6_LXDE-Image 2.8b6.184 20190401”. I tried to use the following two methods to rotate the display,
Please see here for the rotation command that i use:
xrandr --output “DISP3 BG - DI1” --rotate left
Please the photos below for what i see here,
Original display setting without rotation,
[upload|y2XbIlp4OeLtPO+HzfV7nwHSztU=]
Original display setting with xrandr rotation,
[upload|5bpc1DXlo/OMZoQkDNoe0Rr1NJk=]
Original display setting with display rotation and use mouse to move cursor to recover some background image,
[upload|0XF+lgH7fW6DWkun5ZgMDPi/lHQ=]
May i know do you see the same thing as me after using the xrandr to rotate the display? This is using the original software “Apalis-iMX6_LXDE-Image 2.8b6.184 20190401”
But how come the background image is disappeared after the rotation and only when the Mouse cursor move to there then it’s become recovered? Any way to fix the background display issue?
