Hey Guys,
i have a tiny issue with my Display.
So i used the standard RGB display out x20 of the developer board and connected a 24Bit rgb display to the 18Bit interface with setting the 2 LSB of each colour to ground.
Everything works as it should. Even the colors. Exept some sort of timing. Vsync and Hsync are connected but every second vertical line is shifted by one Pixel. Is there like a register setting or a specific Pin I have to connect except Hsync, Vsync, Data Clock, Data enable and all the 18 rgb channel?
Daniel
