Disable the onboard Wifi for verdin imx8mp with wifi
I would like to disable the onboard wifi because want to test another wifi card on m.2 pcie. How do I do that? Is there a special dtb file that can be loaded?
Thank you for your help.
Rahmanu
Hi @rahmanuh ,
Do you want to do this permanently?
You can do this temporarily in the command line by typing connmanctl disable wifi
Kevin
Hi Kevin,
Thanks for the feedback. I want to do that temporarily. I am not sure if connmanctl is what I look for. For my case, I sometime will need to disable the onboard wifi during booting when I want to test an external wifi module on m.2 pcie slot. Maybe I better use imx8mp verdin no-wifi than the one with wifi onboard.
Rahmanu
