I’m using wince6 for my application. During boot i do not want to show any images ( disable splash screen).
But as soon as i disable it(Disable Splash Screen on Windows CE), screen getting complete blank.
How do i disable booting contents showing along with toradex image?
I have gone thru this link, but black image is not available there.
If you disable splash screen you need to save display settings in registry.
You also need to set this flag for operating system to use registry settings.
yes,there is difference in both setting. Currently we are using 7" touch screen having resolution 800x480. So I think registry settings are getting loaded with splash screen enabled. But when disabled, i don’t know whats happening.
Pls find below bootloader display settings
Please update the Black splash screen, this way you prevent to show the booting contents
Update Splash Screen:
Place this .dat file on a SD card and connect the card with the Vybrid module. The splash screen can be updated in the following two ways:
