I am unable to generated a .config identical to the one pulled from a device. There are 2 differences:
CONFIG_LOCALVERSION
- Generated is shows
- From device shows
="-3.0.4"
CONFIG_MXC_GPU_VIV
The generated .config
has this enabled via =y
, while the device does not have this set.
Can someone explain this difference? I would like to make modifications to the config to enable tracefs
, but would some assurance that those will be the only modifications.
HI @fettersa
Which branch with which git revision did you compile?
@jaski.tx I generated the config at SHA baa6c24240a4c9e871e14c056a3485f98fef4dee on branch toradex_4.14-2.0.x-imx
I may be confused. The SHA is correct, but I am not confident it is on the toradex_4.14-2.0.x-imx
branch. I assumed it was since the Kernel build instructions list it Build U-Boot and Linux Kernel from Source Code | Toradex Developer Center
Some investigation reveals baa6c24240a4c9e871e14c056a3485f98fef4dee
to be on toradex_4.14-2.3.x-imx
branch. Is the documentation I linked to out of date? Where should I be building from?
Hi
You are right. It is the toradex_4.14-2.3.x-imx
branch. We will update the documentation soon.
I am still having this issue on baa6c24240a4c9e871e14c056a3485f98fef4dee
May I ask which issues are you having?
The generated config does not match the one pulled from the device. I generated the config while on the Apalis-iMX8_Console-Image_3.0b4.254-20200421 tag.
Hi @fettersa
Regarding your issue, an OpenEmbedded build will change the config in two points:
- LOCALVERSION_AUTO in the the following .bbclass, what is printed as kernel and also module verison
- CONFIG_MXC_GPU_VIV in the following .bbclass, since in the OpenEmbedded Build this driver is build as external module. The advantage of this is the version of the kernel has not absolutely to match with the version of grahic components in UserSpace.Therefore you see these differences.
For a Build outside of OpenEmbedded, you should ignore the LOCALVERSION and set the CONFIG_MXC_GPU_VIV
to y. Hence you need to create the kernel modules by yourself and copy them to the SoM.
Thanks for the clarification. Is OpenEmbedded the supported build method for the LinuxBSP’s available on BSP Layers and Reference Images for Yocto Project Software | Toradex Developer Center ?
I had assumed that the instructions here were how the image was generated: Build U-Boot and Linux Kernel from Source Code | Toradex Developer Center
Is it possible to modify the configuration in OpenEmbedded? Specifically I’m wanting to enable tracefs
support (via CONFIG_TRACING
and CONFIG_FTRACE
among others).
Hi
Yes. Please have a look here.
Yes, it is discussed here.
