I’m trying to use gpio3_io13 to control the poweroff function in Linux. So far I have not been able to get this to work. I have been looking at the NXP document (IMX8QMRM_referenceManual.pdf) for hours. I’m hoping you can point me in a better direction.
Here are my devicetree settings:
gpio-poweroff {
compatible = "gpio-poweroff";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_poweroff>;
gpios = <&gpio3 13 GPIO_ACTIVE_LOW>;
pinctrl_poweroff: pwroffgrp {
fsl,pins = <
SC_P_SAI1_RXD_LSIO_GPIO3_IO13 0x00000021
When the reset signal comes, it drops from 3.3v to 2.5v. I’m guessing the pin is going to a high impedance state rather than a LOW.
The line does go low when I send a command line: gpioset 3 13=0
I have no idea what 0x00000021 is doing. Can you direct me to which section, of which NXP document that describes this settings?
Are you able to see what I am doing wrong?
