Hi @hfranco.tx ,
I stumbled on the next “challenge”…
The device tree that I managed to get working was very simple in that it only disabled UART2:
test_imx7d-colibri-emmc-interferometer.dts (1.1 KB)
When replacing this file with the files I successfully used on the Torizon project for the same custom board, I stumbled into errors.
My device tree structure is as follows:
- The top .dts file is called
- It includes two other files:
#include “imx7d-colibri-emmc.dtsi”
#include “imx7-colibri-interferometer.dtsi”
- The second one is created by me
- I also modified “imx7-colibri.dtsi” which is included somewhere along the line
The result is that there are the only three files under meta-customer/recipes-kernel/linux/linux-toradex. linux-toradex%.bbappend takes care of copying them to the right place :
FILESEXTRAPATHS_prepend := "${THISDIR}/linux-toradex:"
# Prevent the use of in-tree defconfig
unset KBUILD_DEFCONFIG
#--- We're adding some custom device tree files and a "defconfig" that configures the linux modules that are to be included
SRC_URI += "\
file://imx7d-colibri-emmc-interferometer.dts \
file://imx7-colibri-interferometer.dtsi \
file://imx7-colibri.dtsi \
file://colibri_imx7_defconfig \
do_configure_append() {
# For arm32 bit devices
cp ${WORKDIR}/imx7d-colibri-emmc-interferometer.dts ${S}/arch/arm/boot/dts
cp ${WORKDIR}/imx7-colibri-interferometer.dtsi ${S}/arch/arm/boot/dts
cp ${WORKDIR}/imx7-colibri.dtsi ${S}/arch/arm/boot/dts
These are the three files:
imx7d-colibri-emmc-interferometer.dts (2.4 KB)
imx7-colibri-interferometer.dtsi (5.4 KB)
imx7-colibri.dtsi (28.7 KB)
When I ran bitbake, I got an error "Reference to non-existent node or label “reg_3v3"”:
| DTC arch/arm/boot/dts/imx7d-colibri-emmc-iris-v2.dtb
| /home/jeroen/Interferometer/yocto/oe-core/build/tmp/work-shared/colibri-imx7-emmc/kernel-source/arch/arm/boot/dts/imx7-colibri.dtsi:59.23-89.4: ERROR (phandle_references): /panel-dpi: Reference to non-existent node or label "reg_3v3"
| ERROR: Input tree has errors, aborting (use -f to force output)
| make[2]: *** [scripts/Makefile.lib:285: arch/arm/boot/dts/imx7d-colibri-emmc-iris-v2.dtb] Error 2
| make[1]: *** [/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work-shared/colibri-imx7-emmc/kernel-source/Makefile:1270: imx7d-colibri-emmc-iris-v2.dtb] Error 2
| make: *** [/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work-shared/colibri-imx7-emmc/kernel-source/Makefile:179: sub-make] Error 2
| ERROR: oe_runmake failed
| ERROR: Execution of '/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/temp/run.do_compile.2468614' failed with exit code 1
ERROR: Task (/home/jeroen/Interferometer/yocto/oe-core/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_5.4-2.3.x.bb:do_compile) failed with exit code '1'
Since I do not use the panel-dpi in which the reg_3v3 was referred to, I commented that part r and disabled the panel-dpi device.
I then got another error. the really strange thing is that it now complaning about “lcd_panel_in” and about the file arch/arm/boot/dts/imx7d-colibri-emmc-iris-v2.dtb.
So where does the “iris” part come from ???
| NOTE: make -j 7 HOSTCC=gcc -isystem/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/lib -L/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 HOSTCPP=gcc -E HOSTCXX=g++ -isystem/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/lib -L/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/lib -Wl,--enable-new-dtags -Wl,-rpath-link,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 imx7d-colibri-emmc-eval-v3.dtb CC=arm-tdx-linux-gnueabi-gcc -mno-thumb-interwork -marm -fuse-ld=bfd -fmacro-prefix-map=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0=/usr/src/debug/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0 -fdebug-prefix-map=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0=/usr/src/debug/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0 -fdebug-prefix-map=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot= -fdebug-prefix-map=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work-shared/colibri-imx7-emmc/kernel-source=/usr/src/kernel -fdebug-prefix-map=/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work-shared/colibri-imx7-emmc/kernel-build-artifacts=/usr/src/kernel LD=arm-tdx-linux-gnueabi-ld.bfd LOADADDR=0x81000000
| DTC arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dtb
| /home/jeroen/Interferometer/yocto/oe-core/build/tmp/work-shared/colibri-imx7-emmc/kernel-source/arch/arm/boot/dts/imx7-colibri.dtsi:516.23-518.5: ERROR (phandle_references): /soc/aips-bus@30400000/lcdif@30730000/port/endpoint: Reference to non-existent node or label "lcd_panel_in"
| make[2]: *** [scripts/Makefile.lib:285: arch/arm/boot/dts/imx7d-colibri-emmc-eval-v3.dtb] Error 2
| make[1]: *** [/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work-shared/colibri-imx7-emmc/kernel-source/Makefile:1270: imx7d-colibri-emmc-eval-v3.dtb] Error 2
| ERROR: Execution of '/home/jeroen/Interferometer/yocto/oe-core/build/tmp/work/colibri_imx7_emmc-tdx-linux-gnueabi/linux-toradex/5.4.193+gitAUTOINC+f782992971-r0/temp/run.do_compile.2322216' failed with exit code 1
NOTE: Tasks Summary: Attempted 5746 tasks of which 5714 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 7 seconds
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Sorry for the quite lengthy error message but it may provide you some insight.
I also made a tar file of the entire meta-customer directory :
meta-customer.tar (240 KB)
The original "imx7-colibri.dtsi " came from https://github.com/toradex/device-trees by the way
Any help on resolving the “reg_3v3” problem is very much appreciated…
Jeroen
