Noted @amrbekhit. Will do so
Dear @amrbekhit,
we could get our hands in a SGTL5000 breakout board and we could test some configurations, and I believe we got a working solution.
In the dts you sent us, you don’t need to set all of the SAI3 node but just only the newly set pinctrl:
&sai3 {
#sound-dai-cells = <0>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_sai3>;
With this we got the following:
root@colibri-imx6ull:~# dmesg | grep sgtl
[ 2.347243] sgtl5000 0-000a: sgtl5000 revision 0x11
[ 2.359041] sgtl5000 0-000a: Using internal LDO instead of VDDD: check ER1
[ 2.430388] imx-sgtl5000 sound: sgtl5000 <-> 2030000.sai mapping ok
[ 5.915902] #0: imx-audio-sgtl5000
Kindly try and let us know.
I’ve also changed the pinmux values of the pins to the ones used in the Apalis iMX6:
pinctrl_sai3: sai3grp {
fsl,pins = <
MX6UL_PAD_LCD_DATA13__SAI3_TX_BCLK 0x130b0 //X1 54 - SCK
MX6UL_PAD_LCD_ENABLE__SAI3_TX_SYNC 0x130b0 //x1 52 - WS
MX6UL_PAD_LCD_DATA15__SAI3_TX_DATA 0x130b0 //X1 64 - SDIN
MX6UL_PAD_LCD_DATA14__SAI3_RX_DATA 0x130b0 //X1 66 - SDOUT
MX6UL_PAD_LCD_DATA09__SAI3_MCLK 0x130b0 //X1 48
Thanks and regards, Alvaro.
@alvaro.tx Thanks very much for your help, it’s working now. In addition to the wiring issue, it looks like the fsl,sai-mclk-direction-output; entry in the device tree was causing issues.
Dear @amrbekhit , many thanks for the positive confirmation! Not sure if you will be using any internal clocks at the end, but it should be possible with the proper configuration.
