Device tree compilation failed.How to compile device tree
Details are as follows:
DTC     arch/arm/boot/dts/vf610-colibri-eval-v3.dtb
In file included from arch/arm/boot/dts/vf500.dtsi:11:0,
                 from arch/arm/boot/dts/vf610.dtsi:10,
                 from arch/arm/boot/dts/vf610-colibri.dtsi:10,
                 from arch/arm/boot/dts/vf610-colibri-eval-v3.dts:11:
arch/arm/boot/dts/vfxxx.dtsi:11:43: fatal error: dt-bindings/clock/vf610-clock.h: No such file or directory
#include ^
Can you compile by running
make vf610-colibri-eval-v3.dtb
No.Same error is coming.
git -diff output:
diff --git a/arch/arm/boot/dts/include/dt-bindings b/arch/arm/boot/dts/include/dt-bindings
deleted file mode 120000
index 08c00e4..0000000
--- a/arch/arm/boot/dts/include/dt-bindings
+++ /dev/null
@@ -1 +0,0 @@
-../../../../../include/dt-bindings
\ No newline at end of file
diff --git a/arch/arm64/boot/dts/include/dt-bindings b/arch/arm64/boot/dts/include/dt-bindings
--- a/arch/arm64/boot/dts/include/dt-bindings
+++ /dev/null
@@ -1 +0,0 @@
diff --git a/arch/cris/boot/dts/include/dt-bindings b/arch/cris/boot/dts/include/dt-bindings
--- a/arch/cris/boot/dts/include/dt-bindings
+++ /dev/null
@@ -1 +0,0 @@
diff --git a/arch/metag/boot/dts/include/dt-bindings b/arch/metag/boot/dts/include/dt-bindings
t-bindings
+++ /dev/null
@@ -1 +0,0 @@
de/dt-bindings
+++ /dev/null
An untouched kernel source tree should return no output for git diff. Remove the existing one and try again by cloning the source.
Or may be you can force checkout to toradex_vf_4.4 branch and try again.
# git checkout -f remotes/origin/toradex_vf_4.4
