i get the following error when trying to provision a device in torizon ota platform.
== Registering device (deviceID: apalis-imx8-067384XX) in system, and downloading credentials.
Failed to download token :(
HTTP ERROR 401
{"exp":"token expired"}
HTTP ERROR 401
Hi @nkj
Can you describe a bit how you managed to produce this error? I know the tokens will expire so if you waited a bit after pulling up the command to provision a device, it’s possible that the token is legitimately expired.
Drew
Hi @drew.tx
I went to app.torizon.io website. clicked provision device and than copied and pasted it on the serial console. so was less than 5 seconds in terms of time interval.
Nitish
If you refresh the window and get a new provisioning command, does it still fail?
hi @drew.tx yes. i have tried as well signing out of torizon platform and signing back in. i also tried registering two different boards but both give the same error. in the past this always seemed to work.
hi @drew.tx
i tried as well with a different internet connection and there as well not able to provision the device but getting a slightly different error
HTTP ERROR 502
{"name":"BAD_GATEWAY","description":"No resource or matching url pattern found to verify access. Misconfigured gateway.","code":"502"}
Hi @nkj
The dev team found the root cause of your 502 error and have rolled out a fix. Can you recheck and confirm?
Also, can you check if the original issue still occurs?
Drew
Yes that seems to have fixed the problem. I was able to provision the device.
