I want to use the command line to find out which board was used. In my case I use both the VF61 and the iMX6. Is there a way to do this without adding an extra file to the image?
Exactly what I was looking for, thank you.
Hi @Daniel
You see the hardware type if you look for the cpu informations:
root@colibri-imx6:~# cat /proc/cpuinfo | grep Hardware
Hardware : Freescale i.MX6 Quad/DualLite (Device Tree)
root@colibri-vf:~# cat /proc/cpuinfo | grep Hardware
Hardware : Freescale Vybrid VF5xx/VF6xx (Device Tree)
Best regards, Diego
