In my docker.compose.yml, I have lines like this:
image: ${DOCKER_LOGIN}/myapp:${TAG}
This is how the “image” field is defined by default in the Torizon single-container template.
My problem is: when I deploy the docker-compose.yml to the target, it will have these environment variables which are not set. In fact, when I run the build task, DOCKER_LOGIN bizarrely is given the value 192.168.11.119:5002 (my own PC’s IP address).
What do I do when I deploy this docker-compose.yml file to /var/sota/storage/docker-compose? Do I hard-code my own PC’s IP address in the yml file to replace the environment variable? That seems very wrong to me.
Hello! Great question—this situation is common when moving from development to production with Torizon.
The ${DOCKER_LOGIN} environment variable being set to your local IP (e.g., 192.168.11.119:5002) is indeed expected during development, as this refers to your development-time local container registry. However, this is not suitable for production deployment.
For production deployment, you should not hard-code your PC’s IP address. Instead, you should use the dedicated task for production images, which manages this substitution properly.
Steps for Production Deployment
Use the create-production-image Task:
This special task will:
- Build your container image
- Push it to a public or private container registry (like DockerHub)
- Automatically generate a
docker-compose.prod.yml file
In this file, environment variables like ${DOCKER_LOGIN} and ${TAG} are replaced with the actual values (e.g., your DockerHub login and correct image tag), making it safe to deploy on your target device.
Deploy the docker-compose.prod.yml Instead:
- After running the task, use the generated
docker-compose.prod.yml for the deployment to /var/sota/storage/docker-compose instead of your original docker-compose.yml.
- Do not manually edit or hard-code values into your
.yml files.
If you need changes:
- Update your original
docker-compose.yml
- Re-run the
create-production-image task
- Deploy the newly generated
Summary:
No, you should not hard-code your PC’s IP in the docker-compose.yml. Always prepare your application for production using the create-production-image task—the system will substitute variables with the right values.
For more details, see the documentation:
Which docker-compose should I use as the docker-compose in my torizoncore-builder bundle step? Should I create the docker-compose-production.yml then copy-paste it into my torizoncore project? Can I refer to it directly from my torizoncore builder project?
The image: field should point to the Docker registry your container image is stored. The extension has tasks that will automatically do this for you as documented here: Build, Test and Push Applications for Production | Toradex Developer Center
This includes creating a final production ready docker-compose file.
You can ignore the section about Torizon Cloud if you are not using this, as this would not apply to you.
