Thank you @andy.tx for your response.
Unfortunately it did not help us get any further in our troubleshooting.
The issue we are facing is that we have had a number of faulty units returned from customers after some time in use. The problem with these units is that they don’t boot.
Reflashing the file system solves the problem.
On these devices, we are running an old BSP 1.2.
After enabling debug print, we can see the following print during boot:
Toradex Bootloader 1.1 for Colibri Built Jul 12 2013
Press [SPACE] to enter Bootloader Menu
Unknown Product ID Version not set. SerialNo not set.
RAM: 512 MB, CarveOut: 64 MB
Locating kernel image in flash...Done(5224)
Jumping to image at 0x00016000...
Toradex Windows CE 7.0 IMAGE 1.2 for Colibri Built Jan 29 2014
L2 cache enabled
MainMemoryEndAddress adjusted from 0x86800000 to 0x9C000000
Main Phys Mem: 0x00000000:0x1BFFFFFF
Carveout Phys: 0x1C000000:0x1FFFFFFF
Cold boot selected
SMP: Active CPUs = 2
Chip Id: 0x20 (Handheld SOC) Major: 0x1 Minor: 0x4 SKU: 0x8
NVRM Initialized shmoo database
PllClocks(Mhz): X=1000, M=666, C=581, P=216, A=24.576
SysClocks(Mhz): CPU=1000, AVP=232, SysBus=232, Mem=333, EMem=666
GraphicClocks(Mhz): Host=108, 3D=111, 2D=111, Epp=111, Mpe=111, Vde=232
Loading FlashFileSystem(NAND)...WARNING: Saved FreeBlock count in TAT (180) doesn't match with TT Table (0)!!
Done(137)
No free blocks Available-find out the reason, bank = 0
ERROR: FreeBlocks = 0 (FreeBeforeFlush = -1)
Error: No free Blk, Region[0]=0 NvNandHandle: FtlStartLba=431, FtlEndLba=3844 FtlStartPba=468, FtlEndPba=4092
Misc start
NumOfBanksOnBoard = 1
NoOfILBanks = 1
PhysBlksPerBank = 4096
ZonesPerBank = 2
PhysBlksPerZone = 2048
PhysBlksPerLogicalBlock = 1
TotalLogicalBlocks = 3413
TotEraseBlks = 4096
NumOfBlksForTT = 16
PgsRegForTT = 4
TtPagesRequiredPerZone = 2
NumOfBlksForTAT = 8
BlksRequiredForTT = 1
PgsAlloctdForTT = 64
ExtraPagesForTTMgmt = 60
LastTTPageUsed = 50
CurrentTatLBInUse = 2
bsc4PgsPerBlk = 6
Misc end
TAT Handler start
tatBlocks[0] bank = 0, block = 4068
tatBlocks[1] bank = 0, block = 4069
tatBlocks[2] bank = 0, block = 4070
tatBlocks[3] bank = 0, block = 4071
tatBlocks[4] bank = 0, block = 4072
tatBlocks[5] bank = 0, block = 4073
tatBlocks[6] bank = 0, block = 4074
tatBlocks[7] bank = 0, block = 4075
ttBlocks[0] bank = 0, block = 4076
ttBlocks[1] bank = 0, block = 4077
ttBlocks[2] bank = 0, block = 4078
ttBlocks[3] bank = 0, block = 4079
ttBlocks[4] bank = 0, block = 4080
ttBlocks[5] bank = 0, block = 4081
ttBlocks[6] bank = 0, block = 4082
ttBlocks[7] bank = 0, block = 4083
ttBlocks[8] bank = 0, block = 4084
ttBlocks[9] bank = 0, block = 4085
ttBlocks[10] bank = 0, block = 4086
ttBlocks[11] bank = 0, block = 4087
ttBlocks[12] bank = 0, block = 4088
ttBlocks[13] bank = 0, block = 4089
ttBlocks[14] bank = 0, block = 4090
ttBlocks[15] bank = 0, block = 4091
tat Block bank = 0, block = 4070
TtAllocBlk[0] bank = 0, block = 4077
lastUsedTTBlock bank = 0, block = 4077
TAT Handler end
TT 32-bit entry format in dump :
Region: b31-b30
BlockNotUsed: b29
BlockGood: b28
DataReserved: b27
SystemReserved: b26
TatReserved: b25
TtReserved: b24
PhysBlkNum: b23-b0
Dumping page 0
**SuperBlock 0 : *0xFFFFFFFF [ -1] [TT RSVD] [TAT RSVD] [SYS-RSVD] [DATA-RES] [GOOD BLK] [FREE BLK] Region3
Dumping page 1
Dumping page 2
Dumping page 3
**SuperBlock 4095 : *0xFFFFFFFF [ -1] [TT RSVD] [TAT RSVD] [SYS-RSVD] [DATA-RES] [GOOD BLK] [FREE BLK] Region3
Total=4096,Free=0,Bad=0,Reserve Data=0,System=4096,Tat=0,Tt=0,Illegal=0,Region0=0,Region1=0,Region2=0,Region3=4096
Exception 'Raised Exception' (0xc0000094): Thread-Id=0100000a(pth=c0819358), Proc-Id=00400002(pprc=862c25e0) 'NK.EXE', VM-active=00400002(pprc=862c25e0 ) 'NK.EXE'
PC=eff2e754(k.coredll.dll+0x0003e754) RA=8009462c(kernel.dll+0x0000e62c) SP=d1aff710, BVA=00000000
Exception 'Raised Exception' (0x116): Thread-Id=0100000a(pth=c0819358), Proc-Id=00400002(pprc=862c25e0) 'NK.EXE', VM-active=00400002(pprc=862c25e0) 'NK .EXE'
PC=eff0eef8(k.coredll.dll+0x0001eef8) RA=8009462c(kernel.dll+0x0000e62c) SP=d1afee28, BVA=ffffffff
Misc start
NoOfILBanks = 1
ZonesPerBank = 2
TotEraseBlks = 4096
NumOfBlksForTT = 16
PgsRegForTT = 4
NumOfBlksForTAT = 8
LastTTPageUsed = 50
bsc4PgsPerBlk = 6
Misc end
TAT Handler start
TAT Handler end
Region: b31-b30
BlockNotUsed: b29
BlockGood: b28
DataReserved: b27
SystemReserved: b26
TatReserved: b25
TtReserved: b24
PhysBlkNum: b23-b0
Dumping page 0
Dumping page 1
Dumping page 2
Dumping page 3
We have done extensive testing to try to recreate the issue on a working device (for example heavy repetitive disk writing, filling the flash memory over and over, removing power during disk write etc.) but have not had any luck in recreating the issue.
Do you have any ideas what might be causing this, and how to solve it?
Or anything else we could try.
