Dbus usage frome node.js app
I want to use dbus to interface my node.js app to some torizon os features.
Which library/approach should I use? I see there is dbus-next but it has no releases since 5 years. Not sure it’s a good idea leveraging on a unmaintained lib.
D-Bus Usage from Node.js on Torizon OS
For interfacing your Node.js application with Torizon OS features via D-Bus, the documentation demonstrates using D-Bus from containers but doesn’t prescribe a specific Node.js library.
Key Requirements
To communicate with system D-Bus services like Aktualizr from your Node.js container, you must ensure the system bus socket is accessible(1). Mount it when running your container:
# docker run -v /run/dbus/system_bus_socket:/run/dbus/system_bus_socket -it <container>
(1)
D-Bus Interface Documentation
Torizon OS 7.4.0 and newer provides granular control of Aktualizr through its D-Bus interface(1). The detailed D-Bus API documentation is available in the Aktualizr project at:
Library Selection Guidance
While the documentation mentions that “users are expected to access the Aktualizr D-Bus API through the appropriate bindings for their programming language of choice”(1), it doesn’t recommend a specific Node.js library.
For testing and reference, the documentation shows using busctl (part of systemd)(2)(1), but for production Node.js applications, you’ll need to select a D-Bus library that fits your maintenance and support requirements.
Related Resources
If you’re looking for a starting point with D-Bus and Python instead, there’s a D-Bus Python sample available(2).
Hello @vix,
I am not a node.js specialist, but from some research it seems that dbus-native could be an alternative.
I still recommend that you do your due-diligence with such library, making sure it is safe and fits your needs.
Bruno
