D-bus interface framework for IPC
Looking for Dbus library or framework high-level abstraction layer for DBus messaging between multiple process communication. where one process can broad cast message to multiple process on the platform.
Please can you suggest any readily available framework from toradex for IPC using D-bus.
Deepak Jewargi
Hi @djewargi,
Please, check the DBusConnection API used for Linux: D-Bus: DBusConnection
Hiago.
Thank you Hiago.
Deepak Jewargi
