Hi All,
I built a custom torizonCore image using the following .yaml file:
input:
easy-installer:
local: images/torizon-core-docker-verdin-imx8mp-Tezi_5.6.0+build.13.tar
customization:
splash-screen: toradexlinux.png
filesystem:
- changes/
device-tree:
include-dirs:
- device-trees/include/
custom: device-trees/dts-arm64/imx8mp-verdin-wifi-dev.dts # modify this file and find the suitable device tree .dts
overlays:
add:
- device-trees/overlays/verdin-imx8mp_lt8912_overlay.dts # find the suitable overlay .dts
kernel:
arguments:
- key1=val1
- key2=val2
output:
easy-installer:
local: output_directory
and I flashed the generated image using Toradex easy installer. However, after reboot the terminal didn’t come up!
I was able to see the loading sign with the splash image icone for few second, but after few second the monitor is blank with no access to terminal.
What should I do to access to the terminal?
Cheers
Hi @user123456789 ,
What carrier board are you using?
How are you trying to access the terminal exactly? Via SSH or serial connection?
What are the contents of the changes
directory?
Lucas Akira
I am using Dahlia carrier board V1.1A
I am trying to access it through a serial connection. My /changes directory is empty, is it ok to leave empty or should it contains some list of folder? and will this impact the output image if it was empty?
EDIT: Modified the question for clarity
I forgot to answer this, but the monitor being blank after the splash screen is expected, given that your custom image doesn’t bundle any containers. Without any graphical program starting after the OS initializes, nothing shows up on the monitor.
Usually the directories referenced in the filesystem
part of the YAML contain most modifications (e.g. addition/deletion of files) made in /etc/
of a selected SoM with TorizonCore: it’s the result of torizoncore-builder isolate, although you can also do so manually.
Leaving the directory empty shouldn’t cause any problems as far as I know, though you could remove this part in your tcbuild.yml if your custom image doesn’t need to have any changes to /etc
Could you confirm the following?
Lucas Akira
Sorry for the late reply.
Thanks again for your answer I appreciate it. I was a bit confused, I didn’t know that I am not supposed to access to see a GUI.
Just to confirm, yes I was able to access the terminal through serial connection (/dev/ttyUSB3)
and to make it work I had to change permission: chmod 0777 /dev/ttyUSB3
and I was able to access the board with no issues
No problem! Glad you managed to solve it.
Just keep in mind that changing permissions in /dev/
is usually not recommended. Normally you would add your user to a group like dialout
that gives you the necessary permissions to use tty ports.
Lucas Akira
Thanks for the advice, I added my USB to the dialout
group and it works
Much appreciated
