Custom LVDS Cable
I need a custom LVDS cable made. Does anyone know of any service that can do this for me?
Custom LVDS Cable Services
Based on the community discussion, I understand the challenge you’re facing with custom LVDS cable manufacturing (1). A community member experienced similar difficulties with terminating connectors and wasted time trying to create custom cables for the Capacitive Touch Display 10.1" LVDS (1).
LVDS Cable Requirements for Toradex Displays
For Toradex LVDS displays, you’ll need to ensure proper connections for (2):
  • LVDS differential pairs for data transmission
  • Power supply connections
  • Ground connections
The Capacitive Touch Display 10.1" LVDS uses a 40-pin LVDS connector and requires both an LVDS cable and a flat ribbon cable for the touch controller (2).
Alternative Solutions
DSI to LVDS Adapter
Consider using the Toradex DSI to LVDS Adapter (3), which:
  • Features a Texas Instruments MIPI DSI to dual-link LVDS bridge
  • Provides an easy-to-use solution for converting MIPI DSI to LVDS
  • Is compatible with Verdin Development Board and Dahlia Carrier Board
  • Suitable for connecting the Capacitive Touch Display 10.1" LVDS
  • Requires no external power supply
Compatible Carrier Boards
The Iris Carrier Board supports the Capacitive Touch Display 10.1" LVDS directly (4), which might eliminate the need for custom cabling depending on your setup.
Technical Specifications
The LVDS interface specifications include (5)(6):
  • LVDS: Low-Voltage Differential Signaling electrical interface standard
  • Can transport high-speed signals over twisted-pair cables
  • Originally developed for Flat Panel Display Link applications
While I don’t have specific information about custom cable manufacturing services in the available documentation, I recommend exploring the DSI to LVDS adapter option as it may provide a more reliable solution than custom cable manufacturing.
There are many companies that offer custom cable manufacturing services. I would recommend searching online for “custom cables near me” to find a local provider that best suits your needs.
