Hello ,
As per the requirement we are trying to include the custom splash-screen at U-boot and followed the below procedure but it didnt work for us. Let me know if i have missed something
1.created an .bmp image of size 640x480 of 8 bit depth using below command
convert testlogo.png -type Palette -colors 224 -depth 8 -compress none -verbose BMP3:testlogo.bmp
2.copied to this location “oecore/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/u-boot-toradex/1_2020.07+gitAUTOINC+0401650db5-r0/git/tools/logos”
3.Compiled u-boot using “bitbake -f -c compile u-boot-toradex”
4.copied the output files ie SPL and u-boot.img to Toradex Easy Installer
5.Install the modified Toradex Easy Installer through usb0 using "boot_targets usb0 mmc1 mmc0 dhcp "
Logo was not displayed in the u-boot.
Note:we also tried coping the output files ie SPL and u-boot.img to Custom Image which was flashed using above Installer but this is also not working.
Toradex Easy Installer Version “colibri-imx6_toradexeasyinstaller_1.8-20181019”
Image Version Colibri-iMX6_Reference-Minimal-Image-Tezi_5.4.0
SOM Colibri IMX6DL
Hello DaveM
We have also enabled CONFIG_DM_VIDEO=y in the “oe-core/build/tmp/work/colibri_imx6-tdx-linux-gnueabi/u-boot-toradex/1_2020.07+gitAUTOINC+0401650db5-r0/git/configs/colibri_imx6_defconfig”. But it is not working.
Yes,Followed the u-boot-splash-screen article and enabled CONFIG_DM_VIDEO=y ,CONFIG_VIDEO_IPUV3=y and CONFIG_CMD_BMP=y in u-boot defconfig and re-flashed.toradex.bmp (301.1 KB)
