We made a custom carrier board for the i.MX7 Colibri based on the Iris board.
Is this file the default device tree for the i.MX7 Colibri ?
How can we recompile the new device tree and integrate it with YOCTO without following this tutorial ?
We are using for example PIN_45 on the module, which GPIO and bank is it ? How can I manage to find easily this information ?
Thank you in advance.
Thank you for your response.
How can I change the device tree by creating a new layer ? I know how to create a layer, but is this accurate for the device tree ? If yes, how ?
Sorry I’m new to this stuff…
Thank for your help
hi, what do you mean by creating a layer?
I already have created my own meta-layer, incorporating libraries and make them work on my board.
But I don’t know I can do this with the device tree.
Joao
March 7, 2018, 9:10am
6
I patch my device trees by creating a .bbappend for the kernel version. I don’t know which one yours is.
In that .bbappend you add the patches for your device trees and that’s it.
Are you doing this just like the response here ?
Thank you for your help.
Joao
March 8, 2018, 3:31pm
8
I haven’t done exactly like that but Option Two: Manual - Kernel Configuration seems like it does the trick.
If you aren’t successful while doing it I can provide you an example.
Regards
I will be glad if you had one…
Thank you for your help !
Joao
March 9, 2018, 2:59pm
10
Hi
Here it is:
My bbappend (applying several patches)
FILESEXTRAPATHS_prepend := "${THISDIR}/linux-toradex-custom:"
SRC_URI += "file://0002-Update-device-trees.patch \
file://0004-Add-nfc-nxp-pn5xx-driver.patch \
file://0005-Add-splash-screen-image.patch \
file://0006-Modify-wireless-driver.patch \
COMPATIBLE_MACHINE = "(apalis-imx6|apalis-imx6-custom)"
then in /linux-toradex-custom I add the patches
Here’s an example of the device tree patch. I create new dts files, I don’t really patch the available ones but you can adapt with a patch command
--- /dev/null
+++ b/arch/arm/boot/dts/imx6qdl-apalis-custom.dtsi
@@ -0,0 +1,1264 @@
(more content here but for example sake it isn’t necessary)
For more info I recommend you to watch Toradex’s Webinars on Yocto Project, they helped me in this regard
Thank you very much !
I’ll try this and let you know for progresses !
Joao
March 12, 2018, 5:08pm
12
I forgot to mention one thing, before you actually do it and reach a dead end… You must also patch the makefile in the /arch/arm/boot/dts/your-machine-folder
so it compiles your customized dts!
Other option is to apply the same .bbappend to the already existent dts.
The approach I mentioned creates a new one.
And don’t forget to add new dts name to the KERNEL_DEVICETREES
in local.conf or the machine configuration.
Your best bet in my opinion is to apply the .bbappend as presented but instead of creating a new one, patch the existent dtsi.
In your Linux environment, I recommend you to install Meld
, on which you cant put two files side-by-side and it can create a patch for you. You just need to modify the destination headers for something like
--- a/arch/arm/boot/dts/your-dtsi-name.dtsi
+++ b/arch/arm/boot/dts/your-dts-name.dtsi
Regards
