I tried to follow the instructions from the Webinar On-Demand: Part 2 (Advanced) - Building Embedded Linux Images with the Yocto Project and created a new layer “meta-ldms”
(tree output)
meta-ldms/
|── conf
│ ├── layer.conf
│ └── machine
│ └── colibri-vf-ldms.conf
├── COPYING.MIT
├── README
├── recipes-bsp
│ └── u-boot
│ ├── u-boot-toradex
│ │ └── 0001-change-standard-dtb-file-to-ldms.patch
│ └── u-boot-toradex_git.bbappend
├── recipes-example
│ └── example
│ └── example.bb
└── recipes-kernel
└── linux
├── linux-toradex-4.4
│ ├── 0001-add-ldms-specific-devicetree.patch
│ ├── 0001-calibrate.c-Added-some-printk-statements.patch
│ ├── 0001-include-ldms-devicetree-in-Makefile.patch
│ └── defconfig
└── linux-toradex_4.4.bbappend
I copied "linux-toradex_4.4.bbappend from ./oe-core/layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.4.bbappend and added some patch files to SRC_URI.
include conf/tdx_version.conf
FILESEXTRAPATHS_prepend := "${THISDIR}/linux-toradex-4.4:"
LOCALVERSION = "-${TDX_VER_ITEM}"
SRCREV = "a126a5e5dc2fcc5cb36af14c89b440cc8e3bab30"
SRCBRANCH = "toradex_vf_4.4"
PR = "2.8b1-ldms"
#SRCREV_use-head-next = "${AUTOREV}"
#SRCBRANCH_use-head-next = "toradex_vf_4.4-next"
SRC_URI += " \
file:///0001-calibrate.c-Added-some-printk-statements.patch \
file:///0001-add-ldms-specific-devicetree.patch \
file:///0001-include-ldms-devicetree-in-Makefile.patch \
file:///defconfig \
COMPATIBLE_MACHINE = "(colibri-vf-ldms)
my colibri-vf-ldms.conf looks like this.
MACHINEOVERRIDES =. "vf:vf50:vf60:"
include conf/machine/include/imx-base.inc
include conf/machine/include/tune-cortexa5.inc
PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex"
KERNEL_IMAGETYPE = "zImage"
KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb \
vf500-colibri-ldms.dtb vf610-colibri-ldms.dtb \
vf500-colibri-aster.dtb vf610-colibri-aster.dtb"
# U-Boot of our newer release read the Kernel and device tree from static UBI volumes,
# hence no need to deploy the kernel binary in the image itself
RDEPENDS_kernel-base = ""
PREFERRED_PROVIDER_u-boot ?= "u-boot-toradex"
PREFERRED_PROVIDER_virtual/bootloader ?= "u-boot-toradex"
PREFERRED_PROVIDER_virtual/kernel-module-mcc ?= "kernel-module-mcc-toradex"
PREFERRED_PROVIDER_virtual/kernel-module-mcc-dev ?= "kernel-module-mcc-toradex"
PREFERRED_VERSION_mqxboot ?= "1.%"
# U-Boot NAND binary includes 0x400 padding required for NAND boot
UBOOT_BINARY ?= "u-boot-nand.imx"
UBOOT_MAKE_TARGET = "u-boot-nand.imx"
UBOOT_MACHINE ?= "colibri_vf_defconfig"
IMAGE_FSTYPES = "wic.gz tar.xz ubifs"
# wic support
WKS_FILE = "sdimage-bootpart.wks"
WIC_CREATE_EXTRA_ARGS_append = " --no-fstab-update"
# Enable free --space-fixup (-F) by default, this allows DFU updates
MKUBIFS_ARGS = " -c 8112 -e 124KiB -m 2KiB -F"
UBINIZE_ARGS = " -p 128KiB -m 2048 -s 2048"
UBI_VOLNAME = "rootfs"
SERIAL_CONSOLE ?= "115200 ttyLP0"
MACHINE_FEATURES += "usbgadget usbhost vfat alsa touchscreen"
When I do “bitbake virtual/kernel” my machine configuration (colibri-vf-ldms) is used correctly, however the linux-toradex_4.4.bbappend file is not used from my layer. Instead, the /oe-core/layers/meta-toradex-nxp/ layer is used.
My layer shows up in
bitbake-layers show-layers,
but not in
bitbake-layers show-appends | grep -A 5 linux-toradex
Any hints?
Torsten Coym
