we have cross compile the code using the makefile mention the below following error has occur while running in the board i have attached it below .
Download - Toradex File Sharing Platformalt text
hi @narbada@
Could you provide the hardware version of your module?
The error is due to user application. You need to debug this.
You are welcome. Thanks for your feedback.
