Creating TPM Sealed Object Always Unseals to Empty Buffer
I can help you troubleshoot your TPM sealing/unsealing issue. First, I need to clarify your exact setup to provide the most accurate guidance.
Setup Clarification Required
Could you please specify which OS and version you’re running on your Ivy+ board? You can get this information by running the tdx-info command on your device. For more details about this command, see: Getting Device Information with Tdx-Info | Toradex Developer Center
TPM Support Context
Based on the available documentation, TPM integration is supported on Toradex hardware. The Mallow Carrier Board features an OPTIGATM TPM SLM 9670 chip for industrial security requirements(1). If you’re developing with TPM functionality, using the Mallow Carrier Board schematics as a reference is highly recommended(1).
Application Development Framework
Your Python application development approach aligns with Torizon’s container-based architecture(2). For Python development specifically, you can reference the Python development guidance(3), and for containerized applications, the Torizon platform provides Docker-based development workflows(2).
Next Steps
Once you provide your OS version information, I can give you more specific guidance for your TPM sealing/unsealing implementation. The exact approach may vary depending on whether you’re using:
  • Torizon OS with containers(2)
  • BSP-based Linux development(3)
  • Specific hardware configurations
For comprehensive TPM implementation details and troubleshooting, the documentation references secure boot implementations(4), though your use case appears to be focused on application-level TPM operations rather than boot-level security.
Please share your OS version details so I can provide more targeted assistance for your specific platform configuration.
