Couldn't open watchdog : permission denied
Hello Toradex Community,
I want to use the watchdog that is native in the Toradex board.
But when I want to open it I get a “Permission denied” error.
Is there a way to change the permission of the file, situed here : “dev/verdin-watchdog”, permanently ?
I don’t want to change the permission of the file, through linux command, everytime my board is restarted.
Thank you for your support,
Muzzy
Hello @Muzzy,
Thanks for reaching out. Could you please try and answer the following questions:
  1. What carrier board do you have?
  2. Are you using TorizonCore or BSP (Please mention with version)
Hello @rudhi.tx,
Thank you for your help,
I am currently using a Yavia dev board and I am using TorizonCore 6.0 version.
Hi @Muzzy ,
you can try to change the permission in a udev rule.
For this you need to create a file like 99-watchdog.rules in the directory /etc/udev/rules.d.
In this file I added the line KERNEL=="watchdog", OWNER="torizon", GROUP="torizon". This changes the owner of the watchdog to the Torizon user.
If you want to be more specific you can see all the attributes of the verdin-watchdog by running udevadm info -a -n /dev/verdin-watchdog
Hope this helps.
Kevin
Hello @kevin.tx,
Thank you for your answer,
I’ve created the file you were talking about in your answer and it solved my “Permission denied” problem,
Thank you again for your help,
Muzzy
Hi @Muzzy,
Thanks for confirming.
Glad that it worked!
Kevin
