Checking the Getting Started with MCUXpresso SDK for EVK-MIMX8MM that comes with the NXP MCU SDK, for both processors MIMX8MM6 and MIMX8MM3, it mentions MIMX8MM6_M4 for the device.
I believe in this case you can stick to MIMX8MM6_M4 option.
Can you please use the MIMX8MM6_M4 and check if also works for you?
I asked to NXP tech support.
They told me that the Getting Started with MCUXpresso SDK for EVK-MIMX8MM has been written and tested with a Mini Quad, that needs MIMX8MM6.
They’re not 100% sure , but probably, for the Mini Dual, the MIMX8MM3_M4 should be used.
Here is the answer from NXP:
Please try setting the MIMX8MM3_M4, that is the CPU for the Mini DualLite. I guess that in the getting started document was tested with a Mini Quad, that is what has more features and cores.
I am sure that both can works well, but I am not sure if then you can have some issues if you use the MIMX8MM6.
But yes, I am totally agree with you: both MIMX8MM3_M4 and MIMX8MM6_M4 works (at least at a first sight).
I tried both the option and, at a firsy sight, both of them work.
I can see the same happen on my side, both of them work. I couldn’t see any differences, I didn’t go into much detail (just tested with the hello world demo). In that case, we should choose the MIMX8MM3_M4 option, although it’s hard to say the difference.
Anyways, thanks for letting us know, I will give this feedback so we can improve our docs.
