What is the exact procedure to obtain core-image-minimal image ready to flash to Colibri iMX6ULL.
I tried to create my layer with:
- conf/local.conf
- recipes-core/images/my_image.bb
What do I have to put in local.conf and in my_image.bb?
Hi @gvnn
Could you provide the software version of you module?
What exactly are you trying to do?
What is your application and your use-case?
I’m using LinuxImage3.0.
I want to obtain a custom image with some patch in kernel (i did it successfully following this guide: 1) and bootloader (i’m working on that). For the rootfs i see that console-tdx-image provides a lot of unneeded packages so i am trying to obtain a minimal image (plus some package that i add with IMAGE_INSTALL).
Then if possible i want to use sysvinit instead of systemd but i don’t understand how to set it.
As already described in the previous thread, either you can build up a minimal image by yourself or remove the not needed packages for the console_tdx_image.
We are not using SysVinit but Systemd in our regular images.
