ERROR: glib-2.0-native-1_2.52.3-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/shiva/oe-core/build/tmp-glibc/work/x86_64-linux/glib-2.0-native/1_2.52.3-r0/temp/log.do_fetch.5000
ERROR: Task (virtual:native:/home/shiva/oe-core/build/…/layers/openembedded-core/meta/recipes-core/glib-2.0/glib-2.0_2.52.3.bb:do_fetch) failed with exit code ‘1’
ERROR: linux-toradex-4.9-1.0.x+gitAUTOINC+1db9f06709-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS=“unix:abstract=/tmp/dbus-3NVzKSmfCM”; export SSH_AUTH_SOCK=“/run/user/1001/keyring/ssh”; export PATH=“/home/shiva/oe-core/layers/openembedded-core/scripts:/home/shiva/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/linux-toradex/4.9-1.0.x+gitAUTOINC+1db9f06709-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi:/home/shiva/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/linux-toradex/4.9-1.0.x+gitAUTOINC+1db9f06709-r0/recipe-sysroot/usr/bin/crossscripts:/home/shiva/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/linux-toradex/4.9-1.0.x+gitAUTOINC+1db9f06709-r0/recipe-sysroot-native/usr/sbin:/home/shiva/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/linux-toradex/4.9-1.0.x+gitAUTOINC+1db9f06709-r0/recipe-sysroot-native/usr/bin:/home/shiva/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/linux-toradex/4.9-1.0.x+gitAUTOINC+1db9f06709-r0/recipe-sysroot-native/sbin:/home/shiva/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/linux-toradex/4.9-1.0.x+gitAUTOINC+1db9f06709-r0/recipe-sysroot-native/bin:/home/shiva/oe-core/layers/openembedded-core/bitbake/bin:/home/shiva/oe-core/build/tmp-glibc/hosttools”; export HOME=“/home/shiva”; git -c core.fsyncobjectfiles=0 checkout -B toradex_4.9-1.0.x-imx 1db9f06709adfa8fbf538ebc0c17b0b29cf693c6 failed with exit code 128, output:
error: inflate: data stream error (incorrect data check)
error: failed to read delta base object 146f406b8f8a4dc25dbc248f4a8dce0dc5447f71 at offset 383352741 from /home/shiva/oe-core/build/downloads/git2/git.toradex.com.linux-toradex.git/objects/pack/pack-ef001512fcda2acafd6b61efb9c23e50a2213ac1.pack
error: failed to read delta base object f2d91f4028cace50888876ef28685c3eff2cb44d at offset 383355243 from /home/shiva/oe-core/build/downloads/git2/git.toradex.com.linux-toradex.git/objects/pack/pack-ef001512fcda2acafd6b61efb9c23e50a2213ac1.pack
error: failed to read delta base object 9f494b75848abc7514c53417a73e627454ba44ad at offset 383356130 from /home/shiva/oe-core/build/downloads/git2/git.toradex.com.linux-toradex.git/objects/pack/pack-ef001512fcda2acafd6b61efb9c23e50a2213ac1.pack
error: failed to read delta base object b1d7d9b0eb86e897ad0b11eb549bb23f11f74348 at offset 383356159 from /home/shiva/oe-core/build/downloads/git2/git.toradex.com.linux-toradex.git/objects/pack/pack-ef001512fcda2acafd6b61efb9c23e50a2213ac1.pack
error: failed to read object 96ae4f5bd0ebf5b905b1ca7ed9d4cd70c28c1fe2 at offset 383356201 from /home/shiva/oe-core/build/downloads/git2/git.toradex.com.linux-toradex.git/objects/pack/pack-ef001512fcda2acafd6b61efb9c23e50a2213ac1.pack
fatal: packed object 96ae4f5bd0ebf5b905b1ca7ed9d4cd70c28c1fe2 (stored in /home/shiva/oe-core/build/downloads/git2/git.toradex.com.linux-toradex.git/objects/pack/pack-ef001512fcda2acafd6b61efb9c23e50a2213ac1.pack) is corrupt
ERROR: linux-toradex-4.9-1.0.x+gitAUTOINC+1db9f06709-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/shiva/oe-core/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/linux-toradex/4.9-1.0.x+gitAUTOINC+1db9f06709-r0/temp/log.do_unpack.6350
ERROR: Task (/home/shiva/oe-core/build/…/layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.9-1.0.x.bb:do_unpack) failed with exit code ‘1’
i want to know where is the problem ?
please do help.
almost from last four weeks we are facing these problems.
my pc details are…
LUBUNTU 16.04 LTS 64bit
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 2
Model name: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
Internet:
Upload speed is 6 mbps
Download speed is 6 mbps
RAM - 2GB
Hard disk - 100GB free space
Please check ABOVE requirements is sufficient for building or not?
