Hi all,
I’m trying to create a custom linux image for my Apalis iMX6q. For legacy reason I have to use ptxdist instead of Yocto/OE.
I have my uImage, my *.dtb and a file called root.tgz which contains the root folder of my operating system.
In order to install this image I tried to adapt the Apalis-iMX6_LXDE-Image_2.7-20180104.tar.bz2, replacing the symbolic links for uImage and dtb (even if I’m using the standard imx6q-apalis-eval.dts, I copied the result of the build operation).
After that I tried to launch the update script with this command:
sudo ./update.sh -m 1 -o /media/usbStick
But the script fails with error
Did not find the devicetrees from KERNEL_DEVICETREE, imx6q-apalis-eval.dtb imx6q-apalis_v1_0-eval.dtb imx6q-apalis-ixora.dtb imx6q-apalis_v1_0-ixora.dtb imx6q-apalis-ixora-v1.1.dtb. Aborting.
If I replace my uImage with the standard one everything works (so far the dtb is in correct position).
I assume that I’m missing something when I build the image.
What could be?
Thanks in advance,
Regards.
Massimo
