Configure Fixed IP Address
Some questions left …
After installing WEC2013, I can move the iMX7 module from the eval board to my IRIS board and start developing? I prefere headless Operation, cause my target System didnt offer any kbd/mouse/Display, so how can I use the GUI? I have heard the RNDIS is an Option, but I cant get any Connection using the Default address 192.168.11.1, even when I temporarely disabled the fire wall of my PC.
I also prefere fixed IP adresses to easily find my modul, is there any Chance to set the IP address?
With best regards
Gerhard
Hi @Grehard
You can enter a fixed IP address through the control panel:
  • START → Settings → Control Panel → [Network and Dial-up Connections] → [ENET1]
Here you can enter the fixed IP. It will be stored in the registry.
To make the changes permanent over a reboot, you need to save the registry:
  • START → Programs → ColibriTools → SaveReg
Regards, Andy
Hi Andy, I am using Colibri imx6ull 256 mb and Voila rev 1.2 carrier board. I want to change the default configuration of USB RNDIS 192.168.11.1 to fixed ip address so to install the images on Ubuntu host machine.
