Three photos taken right after each other, each with the exact same camera settings. Please note the vertical aligned toradex logo, which should not be there but is clearly visible on the screen.
The perceived flicker frequency depends on the refresh rate. I would guess the perceived flicker frequency to be 15 Hz, roughly estimated.
no obviously there are still images with wrong data in between and I guess that this is why the image is perceived as flickering.
I took one photo how the system (or X) comes up after boot: 0142.jpg. (timings see above). No flicker at all. I still was not able to configure the device tree, so that X starts with the intended timings.
All other photos were taken after applying the xrandr commands times (timings see above). ->Flicker problem
please note, that the flicker problem is time variant and occurs only sometimes. (without changing anything). Initializing (and resetting) the display via SPI does not change anything. When no flickering is visible, the ghost images is almost gone as well.
Is there any particular reason for you to set this question on private? With private questions there is no way for the community to provide feedback or profit from any feedback.
