How can I compile a kernel with modified source using bitbake?
Hi
For small changes you would probably want to create patches for your changes and apply them with a *.bbappend to our existing kernel recipes.
For bigger changes you would probably bbappend to change the SRC_URI and SRCREF to point to a revision on your own git server.
Brandon Shibley touches this subject in his webinars “Building Embedded Linux Images with the Yocto Project”
Also the following blog talks about how to customize your OE build.
Max
