We are using APALIS TK1, and after initial flashing of U-Boot and ROOTFS we have the following message on the console.
Is there any solution to remove it ? or to solve it ?
[ 3936.247969] mmc2: Command CRC or END bit error, intmask: c0000
[ 3937.524954] mmc2: card claims to support voltages below the defined range. These will be ignored.
[ 3937.530728] mmc2: error -110 whilst initialising MMC card
[ 3937.677240] sdhci: =========== REGISTER DUMP (mmc2)===========
[ 3937.684240] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 3937.691220] sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 3937.698191] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 3937.705148] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000001
[ 3937.712095] sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 3937.719027] sdhci: Wake-up: 0x00000000 | Clock: 0x00001007
[ 3937.725948] sdhci: Timeout: 0x00000000 | Int stat: 0x00000001
[ 3937.732870] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 3937.739797] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 3937.746724] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f73
[ 3937.753655] sdhci: Cmd: 0x0000371a | Max curr: 0x00000000
[ 3937.760588] sdhci: Host ctl2: 0x00003000
[ 3937.765617] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 3937.772560] sdhci: ===========================================
[ 3937.779516] mmc2: Command CRC or END bit error, intmask: c0000
Thanks in advance for your support
Regards
Thierry
