Colibri VF50/VF61 WinCE Bring-up
I’m in trouble with a problem.
I’m trying to setting-up Computer Module with an Operating System.
The CPU is a VF50 V1.1A and it’s already running normally Linux on it.
I want to change the operative system to Windows Embedded 2013 and I’m following the procedure here:
I start the procedure to Bring-up Colibri VF50/VF61 WinCE but I receive an error.
When I launch the command:
fatload mmc 0:1 ${loadaddr} eboot.img
I receive the error Invalid partition 1
Is it for an SD issue?
Could you help me please?
hi @emmettbrown
How did you formatted the SD Card?
Which FileSystem did you use?
Could you provide the partition table of the SD Card?
Best regards, Jaski
Hello @jaski.tx , thanks for your answer.
Tha SD card is formatted with FAT32, I’ve formatted using Windows 10 file manager probably.
There is only one partition.
Here is a screenshot:
Kind regards;
Giuseppe
Dear @emmettbrown,
There is another option without worrying about u-boot. You can program the module through recovery as described below
This way you can program the module if existing u-boot or e-boot is corrupted on the module. Could you try this method and let us know if it doesn’t work for you.
Thank you very much, it has worked!!
Perfect. Thanks for the feedback.
