I am working on colibri vf50 ( target for custom board ) with carrier board version 1.1A. I have two card Colibri Vf50 ( v1.1 A )modules. Both stopped booting from boot loader. I implemented the steps given on the following link number of times but not entering into recovery mode ( fails at association stage ).
And you are absolutely sure your serial connection is proper? Please note that for the -n parameter to work right one would still need to additionally shorten RTS/CTS on the module side as indicated here. However if you are using a fully hand-shake enabled serial connection you would need to NOT specify the -n parameter to our update.sh script.
