I am having trouble configuring the CAN bus working on the Colibri T30 on the evaluation board (V3.2B). I’ve built and installed the angstrom-lxde-image on the board.
ip link doesn’t show the can0 device, so the MCP2515 driver seem not to be installed:
root@colibri-t30:~# ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue state UNKNOWN mode DEFAULT group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group default
link/ether be:31:69:c2:78:cd brd ff:ff:ff:ff:ff:ff
3: eth0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
link/ether 00:14:2d:29:00:ac brd ff:ff:ff:ff:ff:ff
4: ip6tnl0: <NOARP> mtu 1452 qdisc noop state DOWN mode DEFAULT group default
link/tunnel6 :: brd ::
7: rndis0: <BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 1000
link/ether 8a:9f:04:ed:57:e3 brd ff:ff:ff:ff:ff:ff
root@colibri-t30:~# zcat /proc/config.gz | grep CONFIG_CAN
# CONFIG_CAN is not set
root@colibri-t30:~#
The documentation suggests adding these definitions:
What exact hardware (module and carrier board) and software versions of things are you talking about?
Those definitions would need to be added to its kernel configuration arch/arm/configs/colibri_t30_defconfig. And then you would need re-building the kernel as explained in the following article on our developer website:
The hardware is a Colibri T30 on a Colibri Evaluation Board (V3.2B) and the OS is OpenEmbedded (Angstrom v2017.12 - Kernel, Colibri-T30_LXDE-Image 2.8b6).
I am already able to compile my own kernel with some custom layer, all derived from the toradex LXDE image (toradex branch LinuxImageV2.8). But I am unable to find a way in the yocto framework to modify/append the necessary flags to the defconfig from within my own layer. Of course, I could just edit the mentioned defconfig or the toradex layer, but this is not very portable.
