custom carrier board
As the 24-bit display interface is not as per Colibri Standard. What exact pins did you use for this?
A client recently noticed that we are not getting full 24 bit video, but rather 18 bit.
How exactly did he determine this?
Our u-boot kernel framebuffer arguments are set to 1024x768-24 at 75Hz
And what is the fbset output?
and our Xorg.conf file is also set to 24 bit depth,
What does /var/log/Xorg.0.log say?
but the two least significant bits on each color channel are not working.
How exactly did you determine this?
OS build is V2.6
What exact versions of things are you talking about?
However, both the T30 datasheet and the gpio config tool show the primary functions of these signals as LCD0-HP1, LCD0-HP2, LCD0-VP1, LCD0-HP0, LCD0-DI, and LCD0-PP respectively.
I believe this naming is as per NVIDIA’s datasheet.
If I look at /sys/kernel/debug/tegra_pinmux signals LCD_D0 thru D17 are configured as “TEGRA_MUX_DISPLAYA” whereas D18 through D23 are “TEGRA_MUX_RSVD3”.
Where/how exactly did you come to this conclusion?
I do get a different result:
root@colibri-t30:~# cat /sys/kernel/debug/tegra_pinmux | grep -E 'LCD_D18|LCD_D19|LCD_D20|LCD_D21|LCD_D22|LCD_D23'
{TEGRA_PINGROUP_LCD_D18, TEGRA_MUX_DISPLAYA, TEGRA_PIN_INPUT, TEGRA_PUPD_NORMAL, TEGRA_TRI_NORMAL},
{TEGRA_PINGROUP_LCD_D19, TEGRA_MUX_DISPLAYA, TEGRA_PIN_INPUT, TEGRA_PUPD_NORMAL, TEGRA_TRI_NORMAL},
{TEGRA_PINGROUP_LCD_D20, TEGRA_MUX_DISPLAYA, TEGRA_PIN_INPUT, TEGRA_PUPD_NORMAL, TEGRA_TRI_NORMAL},
{TEGRA_PINGROUP_LCD_D21, TEGRA_MUX_DISPLAYA, TEGRA_PIN_INPUT, TEGRA_PUPD_NORMAL, TEGRA_TRI_NORMAL},
{TEGRA_PINGROUP_LCD_D22, TEGRA_MUX_DISPLAYA, TEGRA_PIN_INPUT, TEGRA_PUPD_NORMAL, TEGRA_TRI_NORMAL},
{TEGRA_PINGROUP_LCD_D23, TEGRA_MUX_DISPLAYA, TEGRA_PIN_INPUT, TEGRA_PUPD_NORMAL, TEGRA_TRI_NORMAL},
BTW: This is with stock BSP V2.6b2 released 2016-07-01.
Do I need to recompile the kernel to enable these signals for 24 bit color?
No, it turns out despite a 24-bit display interface not being Colibri Standard, those pins should already be muxed as such both on Colibri T20 as well as Colibri T30.
However what you may be missing is the depth setting within the struct tegra_dc_out colibri_t30_disp1_out. E.g. on Apalis T30 where a 24-bit display interface is indeed the default this is set to 24.
