Are there any working examples of using CeGetVolumeInfo(). I need something to detect if the SD card is TFAT formatted.
It appears to be depreciated in wincelib_bin_1.8_2325, wincelib_bin_1.9_2429, and toradexcelibraries_2.0-20170524 libraries.
We can provide you some sample code. It is a small command line tool, that allows you to check if the disk is TFAT formatted or not. You can get it from here.
CeGetVolumeInfo is a API that comes from Mircrosoft. Please be aware, that there are also some bugs in the API function, see also our road map issue 19019.
