Colibri Monitor display is overlooked
When MUI is set to Japanese, the lower part of the screen of the Colibri Monitor’s Performance tab is overlooked.
How do I deal with it?
With Colibri Monitor Version 1.7
@kyas,
What is your display resolution?
Please refer this link : https://www.toradex.com/community/questions/20954/how-to-resize-toradex-task-manager-window.html?smartspace=wince, you would get some useful information relevant to your question.
Thank you for your response.
My way of telling was not enough.
Although the screen resolution is 1366 x 768, it does not matter, but as you can see from the image file of the first post, the character under the “colibri monitor” window is overlooked.
I think that this is due to the fact that the character font in the window is “meiryo ui” in Japanese font.
I hope it will be possible to display it without failing even in Japanese fonts.
I am sorry.This problem was my misunderstanding.
If only the Japanese font “Meiryo UI” is installed in the OS, it will be in a condition that it appears like the attached screen. However, in addition to this, when you installed the “MS UI Gothic” font, I understood that the screen is displayed correctly.
I’m sorry to trouble you.
