First, working with Torizon and after applying device tree overlays everything worked “out of the box”.
I build tdx-reference-multimedia-image(BSP 5.0.0) with no problem.
Then I connected your 7" capacitive touchscreen and after some struggle(i needed to add colibri-imx8x_parallel-rgb_overlay.dtbo and display-lt161010_overlay.dtbo) was able to get output on the screen but touch was not working.
When i add colibri-imx8x_atmel-mxt_overlay.dtbo the board doesn’t boot. It gets stuck at Starting kernel …
Could you provide more information about your environment?
For your tests with TorizonCore, which version it was?
About your tdx-reference-multimedia-image, are you building the image with this repo reference? repo init -u Index of /toradex-manifest.git -b dunfell-5.x.y -m tdxref/default.xml
For your Yocto build, please provide me the output of “/etc/os-release” and “/etc/issue”.
If the board gets stuck in that point, you can remove the overlay. Please check this tutorial - Removing a Conflicting DTO.
I’d like to ask you to try the following:
Download one of the latest nightly release of Toradex Easy Installer as detailed here.
Load the Toradex Easy Installer in your Colibri iMX8X (if you have any issues, try it by putting the module in Recovery Mode).
With the Toradex Easy Installer (2.0b6) loaded, go to the “Feeds” option (in the top Menu). In the window that will appear, click the 3rd box, for “Toradex Continuous Integration Server”. It will load the feeds, this may take a while.
In the list that will appear, mark and install one of our latest Toradex Embedded Linux multimedia images, like the Multimedia image 5.1.0-devel-20201014+build.96 or newer.
Then, I ask you to try again to activate your device tree overlay.
If the error persists, I’ll forward this issue to our BSP team.
-For your tests with TorizonCore, which version it was?
TorizonCore with evaluation containers for V1.0B
TorizonCore 4.0.0-devel-202009+build.23 (zeus)
-About your tdx-reference-multimedia-image, are you building the image with this repo reference? repo init -u Index of /toradex-manifest.git -b dunfell-5.x.y -m tdxref/default.xml
Yes
-For your Yocto build, please provide me the output of “/etc/os-release” and “/etc/issue”.
/etc/os-release
ID=tdx-xwayland
NAME="TDX Wayland with XWayland"
VERSION="5.0.0-devel-20201007080350+build.0 (dunfell)"
VERSION_ID=5.0.0-devel-20201007080350-build.0
PRETTY_NAME="TDX Wayland with XWayland 5.0.0-devel-20201007080350+build.0 (dunfell)"
/etc/issue
TDX Wayland with XWayland 5.0.0-devel-20201009081757+build.0 (dunfell) \n \l
Colibri-iMX8X-V10B_Reference-Multimedia-Image
Did like you said and installed a 5.1.0 version from Easy Installer and touch works!
/etc/os-release
ID=tdx-xwayland
VERSION="5.1.0-devel-20201015+build.97 (dunfell)"
VERSION_ID=5.1.0-devel-20201015-build.97
PRETTY_NAME="TDX Wayland with XWayland 5.1.0-devel-20201015+build.97 (dunfell)"
A do have another question. If it’s an easy fix could you tell me what I have to do to get the colibri-imx8x_atmel-mxt_overlay working with 5.0.0. otherwise, I will wait for the release.
