What is the correct TorizonCore with evaluation containers Colibri iMX8DX 1 GB V1.0D?
Greetings @CEK,
The one marked as “TorizonCore with evaluation containers for V1.0C HW” should also be compatible with the 1.0D. As long as you don’t install any image marked explicitly for the 1.0B, then you should be fine.
