Colibri imx7S v.1.1A boot problem
I wanted to flash u-boot on Colibri imx7S v.1.1A with Viola Plus V1.2B following instruction on:
Flash a New Image Using Toradex Easy Installer | Toradex Developer Center
All steps until 4 are doing fine, but I cannot run ‘update’ command because ‘update’ script is not defined.
Earlier when I run ‘setupdate’ command I get following note:
NOTE: The U-Boot provided with this BSP version does not support the
early tapeout/stepping of i.MX 7 used on your module. You still can
update the kernel/device-tree/rootfs manually using:
run prepare_ubi && run update_kernel && run update_fdt && run update_rootfs
I don’t know what to do with this - u-boot is not writing itself to NAND flash and every time I need to load it by update.sh -d command.
Could you try to use a Toradex Easy Installer (Toradex Easy Installer Documentation Overview | Toradex Developer Center) and flash a Linux image? U-Boot should be flashed as well.
