Hello
What is the reason for 0x40000073, what do you want to achieve with 0x40000000
The reason was to set SION bit to get clock signal on output as in this thread:
No matter the value was 0x40000073 or 0x73 I had no clock output on SODIMM 106 pin. Only for a little time on boot with mentioned in first post patch.
We have designed 3 other devices with two active fec controllers with imx6ULL and without need to use external oscillators to drive PHY ics
Finally, after reading iMX7-colibri errata we decided to use external 50MHz oscillator like on Colibri board.
Here is the current device-tree fec2 node that works with ext 50MHz oscillator:
&fec2 {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&pinctrl_enet2>;
pinctrl-1 = <&pinctrl_enet2_sleep>;
clocks = <&clks IMX7D_ENET_AXI_ROOT_CLK>,
<&clks IMX7D_ENET2_TIME_ROOT_CLK>,
<&clks IMX7D_PLL_ENET_MAIN_50M_CLK>;
clock-names = "ipg", "ahb", "ptp", "enet_clk_ref";
assigned-clocks = <&clks IMX7D_ENET2_TIME_ROOT_SRC>,
<&clks IMX7D_ENET2_TIME_ROOT_CLK>;
assigned-clock-parents = <&clks IMX7D_PLL_ENET_MAIN_100M_CLK>;
assigned-clock-rates = <0>, <100000000>;
phy-mode = "rmii";
phy-handle = <ðphy1>;
phy-supply = <®_eth_vbus>;
phy-reset-gpios = <&gpio2 30 GPIO_ACTIVE_LOW>;
phy-reset-duration = <500>;
phy-reset-post-delay = <100>;
fsl,magic-packet;
fsl,mii-exclusive;
nvmem-cells = <ð1_macaddr>;
nvmem-cell-names = "mac-address";
status = "okay";
mdio {
#address-cells = <1>;
#size-cells = <0>;
ethphy1: ethernet-phy@1 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <1>;
pinctrl_enet2: enet2grp {
fsl,pins = <
MX7D_PAD_GPIO1_IO14__ENET2_MDIO 0x1b0b0 /* SODIMM 188 */
MX7D_PAD_GPIO1_IO15__ENET2_MDC 0x1b0b0 /* SODIMM 178 */
MX7D_PAD_EPDC_SDCE0__ENET2_RGMII_RX_CTL 0x73 /* SODIMM 122 */
MX7D_PAD_EPDC_SDCLK__ENET2_RGMII_RD0 0x73 /* SODIMM 114 */
MX7D_PAD_EPDC_SDLE__ENET2_RGMII_RD1 0x73 /* SODIMM 116 */
MX7D_PAD_EPDC_SDCE1__ENET2_RX_ER 0x73 /* SODIMM 124 */
MX7D_PAD_EPDC_GDRL__ENET2_RGMII_TX_CTL 0x73 /* SODIMM 133 */
MX7D_PAD_EPDC_SDCE2__ENET2_RGMII_TD0 0x73 /* SODIMM 127 */
MX7D_PAD_EPDC_SDCE3__ENET2_RGMII_TD1 0x73 /* SODIMM 130 */
MX7D_PAD_EPDC_BDR0__CCM_ENET_REF_CLK2 0x73 /* SODIMM 106 */
MX7D_PAD_EPDC_PWR_COM__GPIO2_IO30 0x73 /* SODIMM 112 - RST */
pinctrl_enet2_sleep: enet2sleepgrp {
fsl,pins = <
MX7D_PAD_GPIO1_IO14__GPIO1_IO14 0x0
MX7D_PAD_GPIO1_IO15__GPIO1_IO15 0x0
MX7D_PAD_EPDC_SDCE0__GPIO2_IO20 0x0
MX7D_PAD_EPDC_SDCLK__GPIO2_IO16 0x0
MX7D_PAD_EPDC_SDLE__GPIO2_IO17 0x0
MX7D_PAD_EPDC_SDCE1__GPIO2_IO21 0x0
MX7D_PAD_EPDC_GDRL__GPIO2_IO26 0x0
MX7D_PAD_EPDC_SDCE2__GPIO2_IO22 0x0
MX7D_PAD_EPDC_SDCE3__GPIO2_IO23 0x0
MX7D_PAD_EPDC_BDR0__GPIO2_IO28 0x0
I will mark this message as solution because fec2 finally works in our device
