Victor
September 20, 2018, 1:20pm
1
Hello.
We have changed graphics settings from 640x480 to 480x272 to fit our display, following all recommended settings in registry. After that Colibri does not start anymore, stopping at “OEMLaunch…”. Clearing the registry from the bootloader does not help. COM-port debug shows the following:
DMA Wait timeout!
GPMI_DEBUG = 0x0.
GPMI_DEBUG2 = 0xfaf140.
GPMI_DEBUG3 = 0x8700000.
ERROR: c:\wince700\platform\toradeximx7\src\common\nand\core\cspnand.c line 661:
Failed Read cs=0, sector=0x9c00
luka.tx
September 25, 2018, 4:48am
3
Hi Victor,
Could you please try and disable multicore. In bootloader type
set pex.mpenable 0
save pex
this will disable multicore. We are working on more permanent solution now.
Victor
September 25, 2018, 8:11am
4
Hi.
Thanks, this helped.
Does this setting reduce functionality?
And what shall I do next - keep it disabled, update or…?
luka.tx
September 25, 2018, 8:36am
5
For now please keep it disabled. We are working on it. I will let you know when we have fix it.
Currently you disable 1 core so you lose some performance on multicore operations.
luka.tx
September 26, 2018, 10:45am
6
We have found the issue. Its in loading of ENET driver that some descriptors get overwritten.
We will publish this to 1.2b4 version.
You can follow our roadmap here to see when we will release it. I expect it to be available soon.
