Colibri IMX6ULL clock freq on boot
I’ve noticed that the boot frequency of the module is 392 MHz which is not the maximum frequency. This leads to higher boot-times (with compressed images).
Could you tell why this is lower? And is it possible to set this to max. to speed-up the boot?
Best regards Pieter
Hello @PiVo ,
Greetings from Toradex Community!
Could you tell us which image you are using and how you measured the boot frequency?
And regarding your question, probably this article is helpful: https://developer.toradex.com/knowledge-base/cpu-frequency-linux
Best regards ,
Janani
